AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Change default file folder
14 REPLIES 14
Message 1 of 15
564 Views, 14 Replies
AutoCad LT 2009
I'm a retired engineer and recreational user of AutoCad. I want to change the default folder to which AutoCad goes when I click on the File Open icon. How do I do that? Thanks for your time. Otto
14 REPLIES 14
Message 2 of 15
kcsalefty
On your open drawing dialog box, drag and drop the folder you want autocadd to open, then just click that folder and select the file you want to open.
Message 3 of 15
I can always get to the folder and file that I want. I know how to do that. What I want is to setup a default folder that will always be displayed in the "Look in:" box when I click on the "Open" icon. I did what you said and found that the folder in which I last selected a file will be the default folder in the "Look in:" box the next time I want to open a file.
My folder setup is one main folder I named AcadData with numerous sub-folders under it. I want the folder AcadData to ALWAYS be the default folder in the "Look in:" box. Is there a way to do that? Thanks for your time. Otto
Message 4 of 15
Look at the REMEMBERFOLDERS variable.
George Drayton CD-CAD Ltd Christchurch New Zealand.
Message 5 of 15
That variable is new to me. Is it asking me to type in the full path, as in C:\..................? Thanks for your response. Otto
Message 6 of 15
From memory it lets you enter a "startup folder name" in the shortcut
you use to start AutoCAD. "Rememberfolders" usually is set to 0 so that
AutoCAD opens the last used folder (or is it the other way around?).
Remembering back to LT2004 is a bit of a challenge and I'm not sure what
the options in 2004 actually were. Have you had a look at the Recently
opened file list - this defaults to the last 4 entries but can be made
to show up to 9 (Options Open and Save).
Message 7 of 15
George
I remember, from many years ago, ACAD14, what you said about entering the desired folder in the shortcut properties and it worked then. I tried it now and it doesn't work. This is not a biggee, as you know, it's just a minor nuisance. Thanks for your help. Otto
Message 8 of 15
That's what the "rememberfolders" variable is for - either standard
AutoCAD (A2000 onwards) or old mode.
Message 9 of 15
George
Let me pursue this "rememberfolders" variable some more. On the command line I type "rememberfolders" and hit Enter. The command line suggest <1> and waits for my input. Exactly what do I type at that point? Again, thanks for your time to help an old engineer. Otto
Message 10 of 15
George
The forum system dropped what Acad suggested as my response. It's "<1>". If it drops that, its "Less than 1 greater than". Thanks. Otto
Message 11 of 15
Charles_Shade
Its all in the help file. What you are asking for is controlled by Windows. You will defualt to the last used folder when opening a file if the variable is set to 1.
Regards, Charles Shade
Message 12 of 15
Charles_Shade
This might also help: http://www.tomshardware.com/forum/33917-45-purpose-start-properties-dialog
Message 13 of 15
Charles_Shade
dbl Edited by: Charles_Shade on Jan 6, 2010 12:49 PM
Message 14 of 15
When AutoCAD send a message to the command line it often puts a number
or setting in < > brackets. Engineers probably think of these as "less
than" and "greater than" symbols. In AutoCAD, a number or value like
<1> means that this value is the default which you can accept by hitting
the "Enter" key. The default is usually the current value. You can
also enter a new value and hit enter. You can usually also use the right
mouse button instead of the "Enter" key and if you are entering a number
you can also use the space bar in lieu of the enter key. Many settings
in AutoCAD are 0 or 1 (off or on).
I hope that this helps.
Message 15 of 15
George
I understood that the symbols are simply showing the default value. I was just describing what I saw. Thanks for your help. You've been very patient. Otto
”Boost
