Show only
Search instead for
I start all my jobs from a drawing standard layers template that I save as the new job.
Latter on, if for any reason I purge layers not used, and I find that I will need them back, I try to insert my layers template as a block, and receive a message of "block insertion failed. What should I do to insert the drawing layers in my drawing as a block?
"STavares" wrote in message
news:f132e58.-1@WebX.maYIadrTaRb...
the new job.
^C^C-INSERT S:/Corporate/Toolbar/SEI-DIM-STYLES;0,0;1;1;0
all it does in insert a blank .dwg with loaded dimension styles.
I have also added the styles to the .dwt that we start with.
The ad center I strayed away from cause we centralized our blocks and yet people have used all different methods to link to them. i.e. symbol manager, tool palettes, design center... etc... etc...
So this instance was just for our tool bar that we pass around.
The macro will allow you in insert multiple times now...
no purging & no exploding.
If you put an asterisk in front of your block name, it'll come in
exploded -- that way the block definition doesn't come in. I prefer to do it
that way so that I don't have sixteen instances of the same empty block
floating around.
wrote in message news:5465840@discussion.autodesk.com...
Here's what I ended up doing.
