I have used a call out bubble and a reference tag from the design center for my drawing. When I go to the Layout view they do not show up in the drawing. What solutuion is there for this problem
Solved by Charles_Shade. Go to Solution.
Is the layer they are on On and Unfrozen in the Viewport?
Are you using these Annotatively in any way?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
They were not locked or frozen but I did have to allow annotation visibility. Thank you for your help
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
You may even mark your own solution
