Hi There,
I'm looking for some help in getting a block to function the way I want it to.
Solved by pendean. Go to Solution.
Solved by Charles_Shade. Go to Solution.
Excellent.
Does the diameter of the circle ever change? You should ba able to add a Scale Action to this if it does for other diameters.
There is a significant cost difference between LT and Full. If you are creating these often then it may be worth it but you may also find just some outside help will get you what you need. (Don't tell the boss that though.) For me Dynamic Blocks and Fields are worth the price of admission alone.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I have access to the full version elseware. Also, I got a quote for over 3grand to get full version, so I dont think the boss will spring for that this year. Maybe next year once I show him how much time I have save the company with this block.
3d capabilities would be nice too.. will have to show them that in the near future too.
The diameter does change, so I will add in the scale feature once I get it working 100%.
PS... love your home designs!
