I need to load 4 various bitmaps into a standard title sheet for a client (they are logos for a controls company). When I have them loaded and "save as" a dwg drawing for AutoCad LT 2010, the bitmaps do not show up when my client opens the file at his end. We have tried to create the same path on our computers where the bitmaps came from but it still did not work.
Does anyone have any suggestions? Is there a bitmap trace in AutoCad Lt 2013?
Thanks for your time
AJ
In the DWG file, open the XREF palette, select the Image in the top section, then in the lower section of the palette the line labeled SAVED PATH should have no drive or folder information listed. If it does, they need to be removed if as you say both the image file and the DWG are in the same exact folder.
Try it. If it doesn't work I suspect your recipient is opening the DWG file from the email client, and not placing both in a folder first: there is no way for AutoCAD to find the referenced image with that method.
