I'm using 2009LT. I'm archiving old jobs, and am binding all the xref's. Is there a keyboard command that will allow me to do this without having to use my mouse? (dislocated index finger on my right hand)
Solved by Charles_Shade. Go to Solution.
Look around and see if that can be called from a Macro or Script.
Someone may have created one and posted it somewhere. Google too.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
If you just enter the commands as you wrote it, it doesn't work. However, it you enter -xref then b then *, it will work. thanks, I can type that one handed.
The tip posted was a menu macro, as others suggested, to creat a button for this action: it was not a type-at-the-commandline instruction.
OP you are correct that the string will not work from the Command Line.
If you place this Macro on a button in the CUI then you will have a one click option for the index finger.
