AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Big bug to fix.
9 REPLIES 9
Message 1 of 10
SA-JPSA
1518 Views, 9 Replies
Big bug to fix.
Big bug to fix. When you want to navigate between tabs presentations using arrows, this is a "rename" from the tabs located below the navigation arrows.
9 REPLIES 9
Message 2 of 10
pendean
in reply to: SA-JPSA
Message 3 of 10
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
+1 with Pendean
Q1) Which ACAD LT exactly ?
Q2) 32 or 64 bits version ?
Q3) Which Windows : Win XP Pro , Win Seven , Win 8.0 , Win 8.1 ?
Q4) Please could you explain a little bit more ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 10
SA-JPSA
I do not speak English very well, excuse me in advance ...
(some sentences are GoogleTranslate)
we are working on big projects, and have a lot of presentations.
when I want to scroll the tabs presentations with the arrow, clicant repeatedly this is a rename of the tab located below the arrow.
our machines:
Windows 7 64 bit
Intel core i7@3.4GHZ
16GB RAM
GeForce GT640
Autocad LT 2014 SP1
We also have a second problem on a machine.
sometimes when we want to insert an XREF, the window is gray and it is not possible to access the file. see attached photo.
usually when the window is in this state, there is an imminent crash. view another image.
Message 5 of 10
braudpat
Hello / Bonjour
You have only ACAD LT 2014 (+ SP1) or others ACAD LT 201X (which one ?) or you have too "complete" ACAD 201X ?
Tu as seulement de l'ACAD LT 2014 (+ SP1) ou autres versions de ACAD LT 201X (lesquelles ?) ou tu as aussi du "vrai" ACAD 201X ?
Have you the problem on specific DWGs or on only ONE or on ALL DWGs ?
Tu as ce genre de probleme sur certains DWGs ou sur UN seul ou sur TOUS les DWGs ?
Is it possible to get (in ZIP format) one of your "bad" DWGs to test ?
Est il possible d'avoir une copie en ZIP de l'un de tes "mauvais" DWGs pour tester ?
DWLD Free for example ...
Patrice BRAUD
Message 6 of 10
pendean
If you can't slow down the double click speed in your mouse driver... Here are some tips on how to quickly switch layouts without accidentally double clicking to rename it: http://www.cadforum.cz/cadforum_en/ana-alternative-way-of-switching-layouts-tip6910
And
http://forums.augi.com/showthread.php?34099-Switching-between-multiple-layouts
Message 7 of 10
SA-JPSA
in reply to: pendean
 @ pendean: it's not a accidentaly dubble click to rename or a problem with the mouse driver, it's a F***** bug, but i can see that later.
 @ braudpat: we work with ACAD LT 2014 and ACAD LT 2013 it's installed but we can uninstall it.
We have problem with a computer not with a DWG. I have re-install ACAD LT 2014 and there is always the problem.
See the below error message:
ERREUR FATALE:  Unhandled Access Violation Reading 0x0024 Exception at ff212853h
04/07/2014 at 10:26:19.996  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\01_DWG\13849_LCDC_EXE.dwg
ERREUR FATALE:  Unhandled c0150014h Exception at 7720f802h
10/10/2013 at 13:15:02.943  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\01_DWG\12 777.dwg
10/10/2013 at 13:15:48.346  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\01_DWG\12 777.dwg
ERREUR FATALE:  Unhandled c0150014h Exception at 774ef802h
10/15/2013 at 13:39:05.942  Dessin:
10/15/2013 at 13:47:35.866  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ERREUR FATALE:  Unhandled c0150014h Exception at 7754f802h
10/30/2013 at 15:18:33.494  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ERREUR FATALE:  Unhandled c0150014h Exception at 7774f802h
10/31/2013 at 06:06:42.012  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\BLOCS_DYN\LUMINAIRES-CALQUE-0.dwg
10/31/2013 at 11:20:14.307  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\Dessin2.dwg
10/31/2013 at 11:21:07.571  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\Dessin2.dwg
ERREUR FATALE:  Unhandled c0150014h Exception at 7718f802h
11/05/2013 at 15:19:47.359  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\13821-201_LAROC_PROJ_CFO\13821-201_LAROC_PROJ_CFO.dwg
ERREUR FATALE:  Unhandled c0150014h Exception at 76f4f802h
11/22/2013 at 13:50:19.056  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\12782-207_GZAD_EXE_RADIO\12782-207_GZAD_EXE_RADIO.dwg
ERREUR FATALE:  Unhandled c0150014h Exception at 76eef802h
01/14/2014 at 15:38:14.164  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\01_DWG\12777_BCF-COURT_EXE_PLANS.dwg
01/14/2014 at 15:38:56.672  Dessin: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\01_DWG\12777_BCF-COURT_EXE_PLANS.dwg
01/23/2014 at 09:55:52.755  Dessin:
Message 8 of 10
braudpat
Hello
Don't uninstall other "good-old" versions of ACAD LT 2013 !
Ne surtout pas De-Installer les anciens "bons-vieux" ACAD LT 2013 !
It's important to have a spare tire ...
C important d'avoir une roue de secours ...
I imagine you have a specific Windows probleme on this PC ... Very difficult to say which one !?
J'imagine que tu as un probleme specifique au Windows de CE PC ... Tres difficile de diagnostiquer !?
Have you tried to open the DWGs in RECOVER Mode ? and then if OK to Re-Save them ?
As tu essaye d'ouvrir tes DWGs en mode RECUPERER ? puis si OK de les Re-Enregistrer ?
You could try to un-install all DotNet Components v4.5x & v4.x Microsoft Software from this PC !?
Tu pourrais essayer de De-Installer tous les composants Dotnet v4.5x & v4.x de ce PC !?
Then you could try to install again your ACAD LT 2014 ...
Puis tu pourrais essayer de Re-Installer ton ACAD LT 2014 ...
Patrice BRAUD
Message 9 of 10
pendean
It's not a bug if you can't run a year old apication that every in else is running fine as an upgrade from an earlier version.
"Fatal Error" messages are system errors, from Windows.
Message 10 of 10
SA-JPSA
Ok. When I have time (I do not know when), I will try to uninstall dotnet and reinstall ACAD LT 2014 and will inform you if it worked.
THX
”Boost
