Learn to se QSAVE, and turn BAK file creation on in OPTIONS command,
AutoSAVE is only there as a last resort if your system crashes and you need
to recover a file. Then you look for SV$ extension files wherever you have
them set to, rename the extension to DWG, and you hopefully get your file
back.
It is never a good idea to just be a patsy and rely on a Windows machine and
AutoCAD to save files for you. Take control, use SAVE.
IMPORTANT: set ISAVEPERCENT to 0 (zero). Also install all patches for
LT2000, especially the PLOTUPDATE patch.
Dean Saadallah
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
