I was running LT on 2 gig of Ram and it kept freezing up, especially with hatches. Installed another 2 gig and no problems
Doug
What is the LT Version?
What is the OS Version?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi Charlie,
Windows 7 Home Premium
Autocad LT 2011
Autocad customer service operator was horrible. She says she can read me the system requirements off their site. So I said I already did that and there is no mention of celeron processors. So she says if it isn't listed it isn't compatible. I hung up.
Win 7 Home Premium I've read, regardless of what the box says, will be a poor performer for LT.
Quadruple the RAM. The OS is using more than the 2 Gig that you have.
The processor will be for others to help you with but my gut tells me your system is inadequate to run LT efficiently.
Also read thru this list that Dean Saadallah has provided:
http://forums.autodesk.com/t5/AutoCAD-LT/Windows-7-and-AutoCAD-LT/m-p/2762628#U2762628
Hardware Discussion area:
http://forums.autodesk.com/t5/Hardware/bd-p/116
Autodesk Supported Graphics Cards List and drivers:
http://www.autodesk.com/autocad-graphicscard
The prollem I have heard about Celeron processors is they don't really perform to whatever number they are listed at -- it's roughly 3/4 of, say, a Pentium or Athlon processor with a similar number. Hence thay are cheaper 😉
I don't know if this still is the case or if this was true, but back when Celerons first appeared the rumor was when a pentium failed to achieve it's full design intent during testing it was then deliberately 'hobbled', labelled a Celeron, and sold to lower tier vendors so as not to throw away the manufactured chip.
