Hi all
I seem to have problems creating Dynamic Blocks with lt 2013.
The parametres will not respond when I try them.
I have worked with 2009 had no problems I not sure if there is a simple icon or keycommand in the block editor I have missed.
Hello
Have you the problem with any dynamic block (previously created) ?
Have you the problem on some specific actions on yours dynamic blocks ?
Or on all actions ?
Have you try to create a new dynamic block (starting from zero) with your LT ?
Have you the problem ?
Have you installed the SP 1.1 for LT 2013 :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20327876&linkID=9240818
Bye, Pat
Patrice BRAUD
Thanks for your reply (Re Dynamic Blocks)
I do not have any problems with dynamic blocks now.
My recent problem was a simple operator error (I had layer 0 switched off)
Excellent.
But since your query mentioned Dynamic Blocks and you had not posted there I thought it may be helpful to you to let you know there is a Forum dedicated to DynBlk's.
Welcome and since you are new to the Forum I thought that this would allow you to explore beyond the LT Forum.
Much information is available to those who seek.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
