AutoCAD LT Forum
Autocad lt 2010 & Autocad 2010 crashes - mfc80u.dll
4 REPLIES 4
866 Views, 4 Replies
I'm using Autocad Lt 2010 and Windows 7, a collegue is using Autocad 2010.
When we select the "File" option from the pulldown menu we're getting the error message :- Fatal Error: Unhandled e06d7363h Exception at 7589d36fh and Autocad crashes and this happens very frequently.
When I do a web search for the solution, the nearest match to the solution is that we may have the incorrect version of the file "MFC80U.dll"
When I do a search  on my computer I have approximately 7 versions of the file.
Which folder does Autocad lt 2010 & Autocad 2010 put their versions of the file "MFC80U.dll". So I can check which version it is and if I need to update it.
Which version does Autocad lt 2010 & Autocad 2010 use.
Thanks in advance.
4 REPLIES 4
pendean
Unfortunately My Cad Manager believes if I run the hotfix it may affect other software. Now I'm left with an Autocad that crashes many, many times day (even now when I select the Open icon).
Not happy
Charles_Shade
What other program will the Hotfix integrate with?
Create a Restore Date and Time and Reset your OS if need be.
pendean
Which software pays the bills? the DLL AutoCAD needed got replaced I suspect, so I'm not sure how to fix it without messing with whatever needed the newer/older DLL file.
”Boost
