Hi
I am having issues running this version.
It locks up on select
Saving takes forever.
completely hangs after pasting.
Bascially unusable, Please help
Windows 8.1 X64, Autocad LT2014 (new install) redone many times.
Problem with and without SP1 installed. (tried it both ways.)
thanks
Hanes
Unfortunately AutoCAD 20xx is not supported in Windows 8.1
You may need to roll back to Win 7 or wait for AutoCAD 2015 although some have succeeded with a prog called LONGBOW (google it). Others have just lucked out running on Win 8.1
DJ
Hello from France
As said DrJohn you have to switch back to Win 8.0 or Seven OR wait a little bit and update to 2015 version ...
But you can try something else !
Please try (if possible !?) to reset the Color Depth Setting of your graphic card to 15/16 bits (32000/65000 colors)
instead of the standard 24/32 bits color mode (16 millions colors) ... sometimes it works !
Patrice BRAUD
