I am running a fully licensed version of AutoCAD 2012 LT on Windows 7. It worked perfectly the last time i used it (several weeks ago). Just today, the program will not fully load. Instead, it displays the load screen for several seconds, pops open the CAD window for just a split-second, then disappears. No warning message popsup. I tried everything I could think of:
Nothing has worked. I am out of ideas. Any solutions here would be GREATLY appreciated. Here are two tips:
"Failed to find node: //configuration/Connect/V drive in XML file:
C:/Program Files/Autodesk/Content Service/Connect.Service.ContentService.exe.config, system error:
-2147020584"
Thanks for any help!
Solved by Charles_Shade. Go to Solution.
Ahh, alright. Well thanks for that lead. I have yet to perform the total un-install you described, but there appear to be 6 different versions of C++ (see attached screenshot of my 'Programs & Features' window). I'm not computer-wise enough to know if 6 is good or bad. 🙂 Also attached is a screenshot of my monitor right before CAD Lt quits on me, if that is any help.
Hello
Just a stupid question :
Have you installed Autodesk Chronicle Software ?
Bye, Pat
Patrice BRAUD
Just a stupid answer:
Nope, i've not installed that. Didn't even know what it was.
Would you be able to point me to where Autodesk discusses uninstalling all Autodesk software & cleaning the registry? I've not dabbled with the registry much and could use a walkthrough.
I uninstalled all 6 versions of C++ & installed all updates (not just the "important" ones) except for the language packs... as you recommended. However, this hasn't worked either. Scratching my head & running out of options at the moment. Any other ideas folks?
Thanks much.
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
