Can Autocad LT import ECW or GeoTIFF Files? So that they are spatially coorect?
Hello
Welcome to the Autodesk/AutoCAD Forums !
With an ACAD MAP (or ACAD CIVIL) I have already (for customers with only ACAD LT) loaded and inserted at the correct position ECW images
then I save the drawing as DXF and then I change inside the DXF the extension .ECW to .JPG and resave the DXF ...
Then with an utility, I convert the ECW Images to JPG with the same name ...
Finally I reloaded the DXF, resave it as DWG and it is OK for an ACAD LT ...
Patrice BRAUD
Hello
YES you need an ACAD MAP or ACAD CIVIL to do the job !
( Inserting at the right position ECW files)
But maybe the 30 days Trial Period could be enough for you !?
Patrice BRAUD
