Hi There,
I just received a new computer, and while trying to transfer my Autocad LT 2013, I have come to realize that the version I had was on a 32 bit computer, while the new computer I have is a 64 bit computer (Windows 7 for both). I originally downloaded the Autocad software from this site as a trial and upgraded later, so I never received any sort of CD or anything. Is there any way to transfer the 32 bit program to a 64 bit program without repurchasing, and if so, how?
Thank you!
-Robin
Thanks, I found the proper link through the wonder of Google and downloaded it. Everything is working fine!
-Robin
how do i transfer aclt12 32 bit software from windows xp to windows 8.1 64 bit newer computer and make it work on the window 8.1 os.
i know how to transfer the software via autodesk's procedure, but making it function properly is i do not know
LT2012 is not supporte4d in Win8/8.1,
Microsoft's website offers many tips on how to run old software in newer WIndow versions. And you can download LT2012 64bit version here if you need it:
1. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
2. Select the choice "Download Links".
3. Select your product, then variant, then version as applicable.
4. You should now be presented with the choice to download your software.
