I am using AutoCAD LT 2015 and I am making a template from AutoCAD, I have around 10 different layout tabs and I add a boarder and a Raster Image Reference to each (for the logo), as I'm doing this I save the file as a .dwg to my desktop, when I have finished I am save the file as a .dwt to my cloud based database. When I open the file to test it, it has deleted an entire layers worth of work (but not the layer itself) but left all others without anything being deleted.
Has anyone else come across this issue??
If so, does anyone have a solution?
Thanks in advance, if anything further is needed, please do ask, I will try and get all the information I can!
Solved by pendean. Go to Solution.
The deletion is occuring in both the DWG file and the DWT.
The template is for an A2 sheet and a seperate A1 sheet, there is a large square box that leaves around 15mm to the edge of the paper and on the right hand side there are 7 boxes of varying size. These then all contain a multiline text box, all the objects are on a standard layer called 'Title Block'. I can try and get a file uploaded of what it looks like if you cannot replicate it from my description.
Yes, I am saving the file to the folder and allowing time for an upload and for it to sync. No, unfortunately it doesn't keep track of it, that I know of, but the folder does tell me that the file I have just saved is saved at the present time.
Thanks for your help.
I am using a .jpeg and using the'Insert, Raster Image Reference, selecting the file, and then adding it to the paper sapce'. We are on 2015 AutoCad currently, however the past template file was on a 2008 version, I am just updating it to the new version with purging the file to reduce the file space. Would that have an effect if the last time it was created, the person made the lines a block? But saying that, how could they be purged from the file if they are in use?
There are no other blocks in the file. It is purely lines and multiline text (if that is what you are asking).
There are on warnings that the image has not been referenced, there are no warnings to say that the file has not been show, not even the recovery manager warning.
I have requested that I upload the file, but I am currently unable to upload any documents of the files. Sorry, thanks for helping so far.
It is currently located on the cloud, along with the .dwt file. I have also checked that the image can find the pathway and it is established.
I didn't make the dwt. file in 2008, wouldn't embedding the image into the drawing make the file size larger?
We have a cad template saved as autocad 2010 for our company, and we dont have any problem opening it with autocad 2011,2012,2013, and 2014.
the problem is, when we install the autocad 2015 to a new pc, the template cannot be used, it only shows errors and texts.
what should i do?
Have you tried to use the " RECOVER " function? if not try it, it may clear any errors and if you had images on the previous template, you may have to reattach them or make sure that the external reference is correct.
To use the recover function just type RECOVER on a blank drawing and double click on the drawing you wish to recover. That may help.
