AutoCAD LT Forum
Autocad LT 2013- "Autocad LT-Low memory"
5 REPLIES 5
jindalsaw
2276 Views, 5 Replies
I am getting error message "Autocad LT-Low memory-
Autocad LT is running out of system memory. Continuing the current operation may result in program failure or loss of data. Do you want to cancel The current operation?"
Product -Autocad LT 2013 with SP1
PC Configuration-Intel Core2 duo 2 GB Ram Win XP pro with sp3
5 REPLIES 5
Charles_Shade
in reply to: jindalsaw
You may very well be with the 2 Gigs of RAM.
What else do you have running while using LT 2013?
pendean
You are running a PC at the bare minimum of the recommended hardware requirements:
http://images.autodesk.com/adsk/files/autocad_lt_2013_enhanced_product_brochure_en.pdf
Minimum means just that: it does not run well, it simply "barely runs". Kind of like a an old underpowered car which still gets you from A to B all the time just fine but you might have to get out and push to go uphill.
Add more RAM, 3-Gig is XP's Limit, and turn off background running applications too (also the ones you don't see or actively turn on, Windows has a ton of them).
jindalsaw
in reply to: Charles_Shade
We have upgrade 2 GB RAM now total ram is 4 GB but still problem occurred.
and no other application is running while using Autocad 2013,
We have observe one thing that  this problem is occurred only for above 50 MB DWG files.
Dilip Prajapati
pendean
Adding more RAM was not enough, did you do the other things suggested to do in WinXP? IMHO you need more RAM and a 64bit OS to run files that are "... 50 MB DWG files...": by chance are these 50MB files also the ones you are having plotting problems with from your previous post?
Also see this tip from Autodesk: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2862058&linkID=9240617
Windows 7 64bit is in your near future, or start splitting those 50MB files into much smaller files and XREF if needed. There is no fix for XP 32bit with those sized files. Sorry.
Charles_Shade
...and your OS is only seeing 3 Gigs of that RAM anyway.
”Boost
