AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Autocad LT 2010,changed drive mappings on the network, No access dwg files
5 REPLIES 5
338 Views, 5 Replies
Autocad LT 2010,
 We have changed drive mappings on network,  re-pointed Auto Cad LT, can not now access dwg  files
ref file or file path missing please make sure network drive avilable. Do i need to repoint autocad to correct  file loction ?
5 REPLIES 5
pendean
Yes, you need to reload all the Xrefs to the new locations (it appears you saved them as full paths).
in reply to: pendean
Hi
Thanks,  have you any instruction how to reload the Xrefs please.
Paul
pendean
You can use the XREF palette (select each then below at the FOUND AT select the new location of the file), or CLASSICXREF command (has a similar FOUND AT entry as you select each).
Thanks again, were do I select  XREF palette ( to change file path ) from is command line or within tools options ?
Paul
pendean
-XREF command (note the dash) for a command line version.
”Boost
