AutoCAD LT Forum
Autocad LT 2002 Gedit Error
31 REPLIES 31
Message 1 of 32
10285 Views, 31 Replies
Hi to all, I use Autocad LT 2002 on WindowsXP;  a few days ago the license of Norton Antivirus expired, so some days without protection are passed.
However today i installed the Norton Internet Security 2012... but now after a few commands, Autocad LT 2002 crashes with the "Internal Error: Gedit 3" message.
I already tried the patch SP1 (Italian), but the error keeps going out.
Thanks in advance.
31 REPLIES 31
Message 2 of 32
drjohn
Dump Norton.  It is a known enemy of AutoCAD.
>>>Here<<< is a fix if you wanna fight it.
DJ
Message 3 of 32
in reply to: drjohn
I'll try this solution .. but i used Norton until now without conflicting with Autocad
Message 4 of 32
Well, i tried to use the Gedit 3 patch but did not work, (i can't install English Locked and English Unloked version of the SP1)... but using the file that Willfogg posted on this thread works well.
http://forums.autodesk.com/t5/AutoCAD-LT/AutoCAD-LT-2002-Installation-on-Windows-Vista/m-p/2641223
It might be to help for someone.
Thanks anyway
Message 5 of 32
Bruce_2012
same exact problem as michele. New Norton = Gedit 3 Error.
I tried the Willfogg file but get an error 114.
Message 6 of 32
Charles_Shade
in reply to: Bruce_2012
Restore the OS to prior to the Norton install.
If that works do as suggested above and dump the Norton.
Message 7 of 32
Bruce_2012
Any recommendations on Security Software known to be compatable with ACLT?
Message 8 of 32
drjohn
AVG ~  http://free.avg.com/us-en/homepage
AVAST!  ~  http://www.avast.com/en-us/index      <------  My fav.
HTH
DJ
[edit]
... and they're FREE!!!!   Smiley Happy
[/edit]
Message 9 of 32
DarrenP
in reply to: drjohn
microsoft also has a free antivirus program
DarrenP
Message 10 of 32
drjohn
in reply to: DarrenP
The OP might want to read  >>>this<<<  first and see if it applies to them.
Message 11 of 32
i am having the same problem with "GEDIT 3" errors after Norton update. Have you found a solution?
Message 12 of 32
DarrenP
did you read this whole thread?
a solution was posted
DarrenP
Message 13 of 32
Charles_Shade
Drop the Norton products.
Upgrade LT to a current release.
Two known solutions.
Message 14 of 32
When I tried to run the fix, I got "error 114: the Autocad LT 2002 update was not applied" Do I need to do something?
Message 15 of 32
same problem "gedit3 error".  removed Norton.  tried fix, but also got "error 114".  anything else?
Message 16 of 32
pendean
Message 17 of 32
ackdesign
I replaced my Norton Antivirus program with VIPRE last night.  I am still getting the GEDIT 3 error.  I also received it in the iterim between removing Norton and installing VIPRE.  I don't think Norton is the problem.
Message 18 of 32
ackdesign
Is there a similar patch for Windows XP users?
Message 19 of 32
Try removing Adobe Reader & updates.
Message 20 of 32
Did removing Adobe fix the problem. because I am having the same problem with the GEDIT 3 after having my computer fixed and the repair company removed AVG and installed Norton.
Michael
”Boost
