Hi everyone,
I am currenty dealing with a question for a project I am working on. I have a complex building, in which all rooms are described by a tag. The tag is a block which contains as attributes several kinds of information about that room (height, finishing, etc.). One attribute is the surface of the room, which is linked to a polyline by a field (if the polyline changes, the surface attribute changes consequently.
Now, basing on the fact that there is a correlation between my block containing the attributes and the polyline (the correlation is given by the surface field), I would like to select polylines in my drawing basing on specific values in my attributes block. Example: I want to select all the polylines which are linked to the blocks containing as an attribute the text "1.1.1.1.1", or the polylines linked to a block containing as an attribute the text "library".
This would save me loads of time to generate some specific drawings.
Despite not finding anything looking around, I am sure I am not the first person having this question, thus I hope a solution is already available! Any help would be highly appreciated.
Welcome to the Forums
The following link should help you (someone else on these forums has posted this tip on their own forum).
http://www.cadforum.cz/cadforum_en/find-and-select-blocks-with-a-given-attribute-tip7669
Howard Walker
