AutoCAD LT General
Active Member
Message 1 of 7 (431 Views)
Autocad 2011 LT opens a file then close
431 Views, 6 Replies
12-04-2012 02:31 AM
Hello, I have an issue with my computer.
Whenever I open a file, it stats loading it, the file appear (ligns etc etc), but then it simply closes.
The program however stays open.
It doesn't do it with all the files I have, mainly the one which have objects created with Archicad.
I am the only one at the office have those issues with those files.
What can I do?
Valued Mentor
bgingerich
Message 2 of 7 (421 Views)
Re: Autocad 2011 LT opens a file then close
12-04-2012 04:34 AM in reply to: ryan.smyth12
How are you opening the file?  Windows Explorer or through the OPEN command?
Does it work to open the files with the RECOVER command?
Other users can open those files no problem?  What is different on your workstation?
(if ("mysolution"=answer) then (click "Accept As Solution"))
Brandon Gingerich
Active Member
Message 3 of 7 (418 Views)
12-04-2012 04:38 AM in reply to: bgingerich
Ok, so opening via windows or the open command had the same happening.
But I tried via recovering the file, and tada, it worked. Thanks.
Valued Mentor
bgingerich
Message 4 of 7 (413 Views)
12-04-2012 04:43 AM in reply to: ryan.smyth12
Glad I could help!
Brandon Gingerich
Active Member
Message 5 of 7 (282 Views)
03-15-2013 09:48 AM in reply to: ryan.smyth12
Hello there, I have the same problem, and I am getting a little bit tired of recovering the same file every time I want to open it.
What should I do? save-as something else?
Active Member
Message 6 of 7 (212 Views)
03-22-2013 06:35 AM in reply to: ryan.smyth12
Hello again.
As I didn't get any answers, I tried copying everything onto a new file.
The problems stayed.
When I recovere the file, it find 36 errors, which it says to be resolved.
What can I do?
Charles_Shade
Message 7 of 7 (207 Views)
03-22-2013 09:30 AM in reply to: ryan.smyth12
Use WBLOCK instead of Copy/Paste.
Then run the AUDIT or open with Recover from the Big Red A drawing utilities menu.
Does that help the file?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
You are not logged in.
Ask the Community
