AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCadLT Registry Bug
4 REPLIES 4
210 Views, 4 Replies
AutoCadLT 2000 (not "i" version) has a bug on installation that a bunch of
the registry keys don't get written correctly. This manifests itelf if you
run a registry cleaner, they get deleted and then the "Properties" window
won't display properly. The only way to correct this is to reinstall the
program.
I find that I need to reinstall AutoCadLT. Has anyone found a correction to
this problem or do I need to live with it?
The bug was noted before in the newsgroup however Autodesk never came up
with a patch, that I am aware of.
Thanks for any help anyone can offer.
Paul P
4 REPLIES 4
This is curious. I have LT2000 loaded. I run both Regclean and SystemSuite
2000 regularly. The latter takes out many LT related keys, but LT seems to put
them back in the next time I run it. No long term problems with the registry
as far as LT is concerned. Running NT4 SP6a. Maybe it's a Win98 problem?
Martin
> program.
> Paul P
Martin,
I am running it under Windows2000. When RegClean cleans, it doesn't get
everything. If you use a more aggressive registry cleaner (Norton's or
Fix-It Utilities), it really finds a bunch of bad links. When you delete
them, you lose the properties tool.
Further investigation shows that a number of the tools and dll's that
AutoCad loads to the Registry are done without a path to where they exist.
That's OK when you have them installed and AutoCad open but a registry
cleaner sees them as a bad link.
Paul P
"Martin Shoemaker" wrote in message
news:3A57C120.5EC62B83@cableaz.com...
SystemSuite
to put
registry
> Martin
of
you
window
> > program.
to
> > Paul P
Paul
I'm new to LT 2000i and running Win98 2nd edition. Unfortunately I agree w/
you concerning System Suite Registry Cleaner and LT. I just ran System Suite
3 Registry Cleaner. Although I previously had no prblems w/ LTI now have the
following error message upon opening LT when it tries to initially bring up
AutoCAD LT Today:
Startup Of AutoCAD Today: Internet Explorer Script Error
-an error has occurred in the script of this page:
Line: 1
Char: 1
Error: Object doesn't support this property or method
Code: 0
URL: file://C:\Program\AutoCADLT2000i\AcToday.htm
Being new I have the following questions:
1. Is there anything I can add/adjust to easily" solve this problem?
2. If not, where would I go to find out how to reinstall LT w/out
loosing my LT preferences, files, etc.?
Sorry for the length of this message, thanks in advance for any advice.
"Paul Proefrock" wrote in message
news:37EDCDAF1976AFD861C84060A3DB5716@in.WebX.SaUCah8kaAW...
> Martin,
> Paul P
> SystemSuite
> to put
> registry
problem?
> > Martin
bunch
> of
> you
> window
the
> > > program.
correction
> to
up
> > > Paul P
Richard,
I'm using AutoCadLT 2000, not 2000i. It distresses me that you have had the
problem, that tells me that AutoDesk hasn't fixed the problem with 2000i
either.
I hope that someone from AutoDesk will see this message. I don't know how we
can get through to them.
As far as reinstall, if you have made any new menus and saved them under a
distinctive name, you will be ok there.
As far as remembering any tweaks you may have performed or preferences, Bad
News: it is not easily recoverable. You will have to do a reinstall and
start over. Sorry.
Paul P
"Richard Turner" wrote in message
news:B84495AF639B09861D918E1733559F36@in.WebX.SaUCah8kaAW...
> Paul
w/
Suite
the
up
> AutoCAD LT Today:
> Line: 1
> Char: 1
> Code: 0
> > Martin,
exist.
> > Paul P
> > SystemSuite
seems
> > to put
> > registry
> problem?
> > > Martin
> bunch
> > of
if
> > you
> > window
> the
> > > > program.
> correction
> > to
came
> up
> > > > Paul P
”Boost
