I have used a copy of AutoCad Lt (bought thru Amazon) for about 9 months. Recently I got a Google Redirect Virus on my PC and took it to a computer service company which put it thru a series of anti virus and malware programs to remove the virus. Since then Autocad has not worked. I have tried reloading the software using both the repair and reload functions of the program with the same results. (no program). What should i do? I can do a complete uninstall and reinstall if you think it best. Don't know if there are issues with a graphics card (all other programs work), an internal setting, Windows XP or something else. It would be nice if Autodesk had a real person in their service department which one could talk to!
What are my options?
MNS
Welcome to the Autodesk Forums!
I suspect that the Service Company ran a Registry Cleaner on your system and removed some Autodesk files form the LT install in the process.
A repair install may set you straight and is worth trying assuming you have the disk.
*First if you wish to go thru the reinstall:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
*Second if you need to talk directly to an Autodesker:
Support Offering: (click the tabs for options)
http://usa.autodesk.com/support-offerings/basic/
Licensing and license tranfer tips and help are at:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18221949&linkID=9240617
Autodesk support is now on Twitter 24/5 (@autodeskhelp): https://twitter.com/AutodeskHelp
With a blog: http://blog.autodeskhelp.com/
Up & Ready Installation and Startup Help (free for new installs):
http://usa.autodesk.com/support-offerings/up-and-ready/
Safety Net / Per Incident Autodesk support (not free):
http://usa.autodesk.com/support-offerings/per-incident/
If you are on subscription, visit your Autodesk Subscription Page for direct Autodesk Help:
http://www.autodesk.com/subscriptionlogin
Contact a Reseller for support (not free):
http://www.autodesk.com/reseller
Customer Error Reporting:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7047344&linkID=9240617
*Third; there are great bits of information in this Forum:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
