AutoCAD LT General
Active Member
epearson117
Message 11 of 33 (4,085 Views)
Re: AutoCad LT 2013 will not install on Windows 7 x64
03-11-2013 01:15 PM in reply to: pendean
The disk has both versions on it.  I have gone on the disk to the 64bit folder, and when I run that it doesn't work either.
*Expert Elite*
pendean
Message 12 of 33 (4,083 Views)
03-11-2013 01:26 PM in reply to: epearson117
Go grab the 64bit trial download from Autodesk's website and use that for the installation.
Empty that TEMP folder listed in the pop-up, do not run anything from there like you did last time.
Ensure that you restart Win7, turn off all running background applications, be logged in as full administrator in Windows 7, and run the downloaded installer. I recommend you perform a complete download first and resist installing while downloading.
If you are still having issues, you need to share all the above information in a repost to the Installation forum at
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
epearson117
Message 13 of 33 (4,063 Views)
03-13-2013 07:18 AM in reply to: pendean
So, I reinstalled Windows 7 x64.  Then downloaded the Trial Software from AutoDesk.  Sure enough it installed correctly.
Thanks for all you help!!
*Expert Elite*
pendean
Message 14 of 33 (4,059 Views)
03-13-2013 07:22 AM in reply to: epearson117
Great news: I suspect (you need to verify it with your IT) that your Windows is set to find and run the first EXE it finds on a disk and that may have been the problem. Worth turning that ability off as it exposes your system to possible virus installations etc.
Active Member
epearson117
Message 15 of 33 (3,814 Views)
04-15-2013 07:46 AM in reply to: pendean
Once again I am experiencing the same problem.  Only this time, I am running the downloaded version from AutoDesk.
I reinstalled Windows 7 x64 on my computer, and when I try to get run the install I get the same error.
Why would the x64 version be trying to run a file from the x86 folder?
Has anyone else seen this issue?
*Expert Elite*
pendean
Message 16 of 33 (3,806 Views)
04-15-2013 08:51 AM in reply to: epearson117
Why did you have to reinstall Win7?
Active Member
epearson117
Message 17 of 33 (3,804 Views)
04-15-2013 08:55 AM in reply to: pendean
I didn't it is a different machine.
But I was able to get it to install.  This time in order to get it to install I had to login as the Local Administrator and turn off my Trend Micro AntiVirus.
Luckily I am the IT admin here so I am able to do these things.
Member
adit
Message 18 of 33 (3,381 Views)
05-20-2013 12:00 PM in reply to: epearson117
Can I add to this discussion because we had the exact same problem as the first email on 3-7-13. The odd thing is that we have two identical laptops running WIN7/64 and two identical copies of AutoCAD LT2013 - and the standard installation worked perfectly on one laptop. Of note, the CD/DVD indicates that it is good for 32/64 bit installations, i.e. no seperate CD.
So I went into the CD and navigated to the x64/en-US folder and ran setup from there. Now it can't find another file - acadltlp.msi. What to do?
Active Member
epearson117
Message 19 of 33 (3,379 Views)
05-20-2013 12:02 PM in reply to: epearson117
Try turning off you AntiVirus completely.  I found that the Trend Micro I was running caused problems.
Member
adit
Message 20 of 33 (3,359 Views)
05-20-2013 03:54 PM in reply to: epearson117
Brilliant - it worked, thank you! And you didn't even know that we were also using Trend Micro AV when you made your suggestion.
You are not logged in.
Announcements
Need installation help?
Ask the Community
