AutoCAD LT General
Active Member
Message 1 of 33 (9,120 Views)
AutoCad LT 2013 will not install on Windows 7 x64
9120 Views, 32 Replies
03-07-2013 01:24 PM
I am unable to install AutoCad LT 2013 on my Windows 7 x64 system.  Everytime I try to install I get the error message:
"The system cannot open the device or file specified.
C:\Users\Eric\AppData\Local\Temp\_AI194B.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013.msi."
I can go to that folder and that file is there.  However, if I try to run that file it then gives me errors about other missing files, that are not in that folder.
I have tried this with Multiple Logins, including the Adminstrator.  I have also, completely wiped out the system and reinstalled Windows 7 from scratch.
I have set the UAC to the lowest level.
I have also tried another DVD, and tried copying the files to the machine.  No matter what I try I get this same message.
One other thing, this is the 2013 Upgrade.
pendean
Message 2 of 33 (9,110 Views)
Re: AutoCad LT 2013 will not install on Windows 7 x64
03-07-2013 02:59 PM in reply to: epearson117
Restart Windows and skip installing all the extra apps that got hung-up (read your error message carefully, it tells you which one). See if that helps.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
Message 3 of 33 (9,083 Views)
03-08-2013 05:53 AM in reply to: pendean
Not sure I understand what you mean?  How do I "skip the install"...I am putting in the DVD and running the applciation...I have tried running the setup from the x64 folder on the dvd, but that didn't help either.
Charles_Shade
Message 4 of 33 (9,081 Views)
03-08-2013 05:56 AM in reply to: epearson117
Is there not a choice to install in a Custom way?
Pick and choose what to install?
Most installation programs have this option though I cannot rmember if CAD does.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Active Member
Message 5 of 33 (9,017 Views)
03-11-2013 11:56 AM in reply to: Charles_Shade
It never gets that far.
I put in the CD I get this window:
I click "Run Setup.exe" I get this window:
Then this winodw pops up:
If I click OK, it closes the install.
pendean
Message 6 of 33 (9,009 Views)
03-11-2013 12:50 PM in reply to: epearson117
Does it help if you navigate to that TEMP folder identified in the po-up and empty it in Windows Explorer?
Active Member
Message 7 of 33 (9,006 Views)
03-11-2013 12:52 PM in reply to: pendean
Nope.  And I have tried running the file it calls out and the just then tells me other files are missing from that temp folder.
DarrenP
Message 8 of 33 (9,004 Views)
03-11-2013 12:56 PM in reply to: epearson117
this may or may not help
try copying the whole DVD to your hard drive and run the install from there
Active Member
Message 9 of 33 (9,001 Views)
03-11-2013 01:00 PM in reply to: DarrenP
Did that, didn't make a difference.  I am thinking this might be a 64-bit issue.  I have a couple of other systems that are running 32-bit and the install worked fine on those.
pendean
Message 10 of 33 (8,995 Views)
03-11-2013 01:10 PM in reply to: epearson117
You do seem to be trying to install trhe 32bit version of LT on Win7 64bit: which will fail all the time.
Navigate to the disk in Windows Explorer and find the 64bit Installation to activate: bet you have the 32bit disk in and that's the problem.
Who has the 64bit disk in your office? If you canot find it, grab the demo from the Autodesk site, it's the same exact product.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
