AutoCAD LT General
New Member
Message 1 of 3 (801 Views)
AutoCad LT 2013 Error Message
801 Views, 2 Replies
08-16-2012 06:44 AM
OS is Windows 7 Enteprise SP1 French
AutoCad LT 2013 installed in french
Running the app with admin priviligaes works fine, but as a standard user we get the following error.
Erruer 1324. Le chemin du dossier "My Pictures" contient un caractere invalide.
Any ideas?
Thanks , I add a screenshot as welll
Charles_Shade
Message 2 of 3 (777 Views)
Re: AutoCad LT 2013 Error Message
08-16-2012 12:16 PM in reply to: bbacoyiannis
Have you started the Seat of LT on the Standard users System as an Admin first, shut down LT, logged off Admin, logged on as Standard User and then tried the LT?
Or doe this have something to do with the Program while it is running?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
New Member
Message 3 of 3 (699 Views)
09-09-2012 04:51 AM in reply to: bbacoyiannis
We had the same error with Autocad 2012 LT (in german  "Fehler 1324. Der Ordnerpfad "Eigene Bilder" enthält ein ungültiges Zeichen.") first starting Autocad.
This Autocad error is caused in our case in a folder redirection policy in active directory (for example "\\server\home\userXY\Eigene Bilder").
A workaround is to edit the registry key "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders\My Pictures" to a path like "C:\temp" or a variable like "%USERPROFILE%". After Autocad was started successfully you can change it back.
You are not logged in.
Ask the Community
