Solved by andrewh07. Go to Solution.
Solved by pendean. Go to Solution.
The first item to look for is Proxy objects being created in the LT 2012 seat and then saved down to 2000.
First thing that comes to mind is MLeaders. Though this shoud not cause a crash.
Do the other users on the other platfroms also save to Release 2000?
Are you mixing Proxy objects from other installs and or adding 3D content?
PROXYGRAPHICS, PROXYSHOW, PROXYNOTICE: Any of these pop up when switching platforms?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
1st: never ever use any commands or features (like Mleader, annotative text and more) that are not found in 2005/2007 if file exchange is something you must do with their files.
2nd: If they can open the file and work in it with no issues but saving is the problem, fix the file(s): ask then to use RECOVER to open the files and see if any errors are reported (and to SAVE soon after opening), and you do the same. Compare findings with each other.
3rd: in addition to the variables (posted by Charlie) that you all three must set to match, in LT2012 what are your settings for "Maintain Fidelity" and "Maintain Drawing Size Compatibility" in Options>Save tab?
4th: LT2012 has EXPORTTOAUTOCAD command to deal with files that must truly and genuinely be knocked down to a lower format. SAVE settings alone keeps to much roundtrip info intact for you to use (reason you must adhere to rule #1 above) that may mess up 2005/2007 which did the same for their lower versions (2002 has no clue about such features).
And finally: are all three of you in the same office? Are all the files on a server or your PC? By chance could the problem just be that your Win7 64bit PC took over the read/write ability of the folder or files and the other WinXP users cannot write to your file locations anymore?
Another thing I forgot to mention is that if I open the drawing in Autocad LT 2010, save it and close it, 2005 and 2007 have no problem with it. Is there something in 2012 that is not in 2010 that is allowing this to happen?
Yes, my problem was fixed when I exploded all the leaders in my drawing. 2005 and 2007 cannot handle leaders with text attached to them, but if you do not use them or at least explode them after you draw them, it should fix the problem..it did for me.
