AutoCAD LT General
Active Member
AdminSaratoga
Message 1 of 5 (566 Views)
AutoCad LT 2007 Unable to Print "The None plot device has been Substituted".
566 Views, 4 Replies
04-25-2012 12:30 PM
I have one workstation running Autocad LT 2007 on a windows 7 32 bit OS, and needs to print to a non plot printer, which is a Kyocera KM-4050 KX. I am unable to print to this printer through Autocad LT 2007 and recieve the following error message . . .
"\\ServerName\PrinterName: This plotter configuration conanot be used for one of these reasons: The driver cannot be found, the device can not be found, or the driver has a problem. The None plot device has been substituted."
The Printer works fine with all other applications, and the rest of the users who have Autocad LT 2011 have no issue printing.
I followed the instructions in http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2897193&linkID=9240617 and did not see my printer model in the list and was unable to load the driver from a disk.I believe the file it was looking for was .hif, which could not be found.
I also uninstalled and reinstalled the printer driver, and did some testing, so the printer works fine except for this application.
Is there a resolution to this issue? According to the user the print function never worked for them in Autocad LT 2007.
*Expert Elite*
Charles_Shade
Message 2 of 5 (564 Views)
Re: AutoCad LT 2007 Unable to Print "The None plot device has been Substitu
04-25-2012 12:42 PM in reply to: AdminSaratoga
Printing and Plotting Forum
Does this user try to plot to the Windows installed printer or to a pc3 file in AutoCAD?
You say the AutoCAD 2011 users have no issue.
What is the OS for the 2011 users?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Active Member
AdminSaratoga
Message 3 of 5 (543 Views)
04-26-2012 10:43 AM in reply to: Charles_Shade
Charles,
The user is trying to print to the windows installed printer. I tried to create a p3, but was unable to do so becuase the wizard was looking for a .hif file that could not be found on the print driver disk. The OS that is being used for the autocad 2011 users is windows 7 32 or 64 bit. About half has 32 bit, while the rest have 64bit.
*Expert Elite*
Charles_Shade
Message 4 of 5 (541 Views)
04-26-2012 10:44 AM in reply to: AdminSaratoga
I'm wondering if the LT 2007 needs an older driver to work and that that is the issue.
*Expert Elite*
pendean
Message 5 of 5 (531 Views)
04-27-2012 05:28 AM in reply to: AdminSaratoga
HIF file prompt is when you go about creating a PC3 file the wrong way: that method actually requires an AutoCAD driver from the printer/plotter manufacturer (not an option in your case). You needed to use the NETWORK option instead.
If the exact setup works on all the other PCs but this one, then this one is very different: could be a driver version number, could be a missing patch or update, or more. Start with a simpler fix: log in as another user on the PC and test it, if it fails, this one computer needs to be re-imaged/reinstalled to matchn all the others 100%.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Announcements
Need installation help?
Ask the Community
