AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD integrity
13 REPLIES 13
Message 1 of 14
derek31a
775 Views, 13 Replies
AutoCAD integrity
I am currently running LT2012, and will hopefully upgrade to LT2014 in the near future (company is a bit slow with upgrades!)
However, my question is this - why, when I produce a drawing in LT, do I get the following message -
"Non Autodesk DWG.  This DWG file was saved by a software application that was
not developed or licensed by Autodesk.  Autodesk cannot guarantee the
application compatibility or integrity of this file."
What's going on - any ideas?
Smiley Sad
13 REPLIES 13
Message 2 of 14
hwalker
in reply to: derek31a
It could have been created in microstation or some element in the drawing was. Or it was an externally created DXF/DWG
Does this always happen?
If it does I suggest you open your template, copy everything in there to the clipboard.
Then open up one of the standard Autocad Templates and paste in there and overwrite your old template.
I have found this happens everytime I use a PDF to DXF converter, and copying and pasting into a drawing I have already saved as Autocad format gets rid of the message every time.
Howard Walker
Left Handed and Proud
Message 3 of 14
derek31a
in reply to: hwalker
Thanks for the reply.
No, it doesn't happen with all drawings.
The last drawing I produced from nothing gives the message, although it was done entirely in AutoCAD. The drawing blank and attributes were produced in AutoCAD - however, P&ID symbols were inserted........and these symbols and blank drawing sheets were created by me, using AutoCAD. I've never used Microstation!
The drawing border templates are stored in a Solidworks EPDM system - would that cause a problem?
Message 4 of 14
dgorsman
If you mean template, as in you copied that file rather than started from a clean, blank "new" AutoCAD drawing - possibly.  The warning simply means the DWG file was produced by non-AutoDesk software, so it may be missing some settings or may have additional data.  Those may or may not cause problems for you later down the road.  Under most cases its a non-issue.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 5 of 14
pendean
How far down do you have save set to in Options?
Are your files unusually large for what little content they have?
Message 6 of 14
derek31a
in reply to: pendean
OK, drawing attached (with company info/details removed).
It's not causing a problem, I just wondered why it opened with the integrity warning - so no need to spend time on it!
As you can see, the file size is small - only 107kb
Message 7 of 14
hwalker
I can never work out how it knows, it must be something in the header of the file, but here is your file back without the annoying message popping up
Howard Walker
Message 8 of 14
derek31a
Thanks HW - as you say, the annoying message is no longer there.
Can I ask what you did? Is it something I can do if the message pops up again on a different drawing!
Definitely worth a Kudos point and solution tick for the answer Smiley Very Happy
Message 9 of 14
derek31a
Dean, not sure I understand your question - do you mean what level do I save drawings as......if so, I save drawings as LT2004 so that everyone in the company/suppliers can open them.
Message 10 of 14
hwalker
All I did was open up the template acadlt.dwt using the FILE NEW, and then just copy and pasted your modelspace and paper space into that template and saved it.
Howard Walker
Message 11 of 14
pendean
I notice the problem appears from predominantly LT2010-LT2011-LT2-12 users (a specific consultant we use) who save files down to LT2004 or lower formant, and not the default 2010 format.
They do it because they have one client, somewhere that we do not interact with, needs the lower format so as a company they decided to cripple everyone with it.
My users find it annoying to say the least: we have since contracturally forced them to not do that so we don;t have to put up with it.
Message 12 of 14
derek31a
Thanks Dean - maybe saving to 2010 is the answer, and let others sort out their incompatibility issues! Would definitely make life easier for me............
Message 13 of 14
pendean
We save down on an as-needed basis for clients that ask nicely (or contractually require it): otherwise we simply provide a link to the free viewer (that converts) along with files we send out.
Message 14 of 14
dgorsman
Same here.  We always work in the "native" DWG version.  If the client wants their files in a lower version, we use TrueView to batch convert them just prior to returning.
”Boost
