AutoCAD LT General
Member
fnegron2
Message 1 of 6 (503 Views)
AutoCAD Lite 2013 (slow publish)
503 Views, 5 Replies
11-29-2012 07:05 AM
I am having a little problem with AutoCAD Lite 2013 and is that when I have 7-10 sheets to publish it is taking a lot longer than other systems. Moreover, the other systems have the exact same performance specifications.
Thank you for your help!
*Expert Elite*
Charles_Shade
Message 2 of 6 (499 Views)
Re: AutoCAD Lite 2013 (slow publish)
11-29-2012 07:52 AM in reply to: fnegron2
Network printer or just Publish to PDF (or File)?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
fnegron2
Message 3 of 6 (496 Views)
Publish to PDF (10-12 sheets takes 10-12 minutes).
11-29-2012 08:04 AM in reply to: Charles_Shade
*Expert Elite*
Charles_Shade
Message 4 of 6 (480 Views)
Re: Publish to PDF (10-12 sheets takes 10-12 minutes).
11-29-2012 09:29 AM in reply to: fnegron2
New occurence or previously ongoing?
If new a System Restore to prior to the problem may help.
What is different about the other machines? And not just specs, programs and add ons.
Member
fnegron2
Message 5 of 6 (471 Views)
11-29-2012 12:29 PM in reply to: Charles_Shade
This is a brand new system and this will be the first time this happens.
*Expert Elite*
pendean
Message 6 of 6 (464 Views)
11-29-2012 03:43 PM in reply to: fnegron2
Do you have background publishing on? Turnit off in OPTIONS command's Plotting tab. It's turned on by default if you just start using a new setup.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Announcements
Need installation help?
Ask the Community
