AutoCAD LT Forum
AutoCAD LT Installation Error
4 REPLIES 4
Paulo.Alao
599 Views, 4 Replies
I have installed AutoCAD 2012 LT on my work machine, but its coming up with an error - "Customization file load failed. File not found: acadlt".
My work machine is controlled by our IT, so the C: drive is locked and I only have temporary admin rights on it. Being a fresh installation, I believe this might be related to the security policies my work machine is under.
Any ideas?
Regards
Paulo Alao
4 REPLIES 4
braudpat
in reply to: Paulo.Alao
Hello
Sorry I am a Frenchie very careful / paranoiac ...
A correct AutoCAD Install (for me) is :
- use a LOCAL Admin Login
- install the software from a CORRECT Master
- I imagine "no error" during install ... The Install can be a Trial/Eval (30 days) Install !
- Reboot
- use ALWAYS a LOCAL Admin Login
- launch the software, test a few DWGs
- download Service Pack / Update Pack and install
- Reboot
- Reboot
- use NOW a NORMAL Login
I know it's long but it's "my procedure" !
For AutoCAD LT 2012, you need SP 2 :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19501802&linkID=9240818
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Paulo.Alao
in reply to: braudpat
Hi Pat,
Thanks for this, I will  try your method tomorrow and let you know.
When you say "install the software from a CORRECT Master", I suppose if I am installing it straight out of the box, its kind of the same?
Paulo
braudpat
Hello
I said "Correct Master" because we experience on forums with people having BAD Master of AutoCAD
(because Bad download from Autodesk Servers)
But I am positive, so I imagine you have o GOOD/VALID Master !?
Bye, Pat
Patrice BRAUD
Paulo.Alao
Pat,
I believe I do. I will test it and let you know the results.
Regards
Paulo
”Boost
