Hi All,
Hope somebody can help me. I have recently upgraded to AutoCAD LT 2015 and works a dream but I keep coming up against the same problem whenever I seem to do a save as. When i modify a DWG and want to do a save as I select the new folder i want it to save into but for some reason it keeps on duplicating the same new file I have saved and saves a copy in the old location aswell???
Is this something that has been built into 2015 or can i switch it off on a setting somewhere?
Many thanks
Hi
Thanks for your reply.
I am not typing any command in. I am just clicking on the save as icon with the pencil and chosing a new location to save it. Once i click this it saves the file in the new location but it creates a duplicate and saves the duplicate in the current location which i don't want it to do.
I previously did the same as what i'm doing now on AutoCAD LT 2013 and 2014 and never had this happen before. I'm not doing any different to what I normally would.
But what command is that executing? It would help to know.
Also, try typing in the 3 different save commands. Any different results?
Well there you go. SaveAs creates a copy of the drawing in a different location that the drawing loaded in the editor (unless you specify the same location).
For example, you open C:\Temp\DrawingA and work on it then run SaveAs and specify the filename C:\My Documents\DrawingA. Now the one in My Documents is current and the one in \Temp is the same as it was when you opened it.
Sorry guys I don't follow,
By saving the edited drawing in a new location (SAVEAS) I know it won't save over the original drawing I am working on but I don't see how it will save the file twice with the new file name (One in it's new location where i want it to save and the a duplicated one in the folder it currently sits).
It has never done this before.
@Anonymous wrote:Hi All,
Many thanks
No. As far as I can tell, this is not something "built into 2015". 😉
Are you saving back to a previous version? Perhaps you could copy/paste your F2 screen (command history) for us to see?
Hello
Just a few questions :
- You are running your LT 2015 on which Window exactly : Win Seven, Win 8.0, Win 8.1 ?
- When you try to save elsewhere with the _SAVEAS command : is it on your Hard Disk or on a logical unit (Network) ?
Patrice BRAUD
I have 2015 LT and I am having trouble with the "Saveas", in just the last few days.
It is trying to save as the same name and overwrite.
Is there a setting that I may be missing ?
