Hi all,
I am very new to AutoCAD (1 day of playing around).
My company is an independant environmental consultancy company that uses GIS (QGIS/shapefiles/.dxf is compatable) to create maps etc. We are generally sent AutoCAD .dwg or .dxf from out clients for the technical drawings of their projects. I have a few questions:
Thanks to anyone who is able to assist!
Rowan
Solved by pendean. Go to Solution.
Welcome to the Autodesk Forums!
1. Ask your client to reference the files to a location for you. This would be the best way to have the information that you need and if it is a matter of them not knowing how it sounds like you have a good start to teach them though not ideal. This is a nice feature but it is a bit inexact. Autodesk Civil would really be the program for you but it does have a huge learning curve. If nothing else they can start froma specified point and draw with a UCS relative to the site.
2. Look into the Layer Tools in Help. There are several ways to accomplish what you ask. Layer States being the most obvious.
Good Luck.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
