I plot drawings dwg to pdf, then open pdf complete and combine multiple pdfs made in AutoCAD LT 2013, it creates a file with 0 KB and does not combine files, I can combine files I create with scaner to pdf, but not the files created in AutoCAD thru plot DWG to PDF, does anyone know of a fix for this?
So you are getting usable PDF's from DWG to PDF?
Are these from multiple drawing files or one drawing file?
From the Publish window, Publich Options do you have Type set as Multi-Sheet File?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
So you want help here in the AutoCAD forum for a 3rd party PDF tools product?
Do you even have valid PDF files before you tried to combine them?
Why not just use PUBLISH command inside LT2013, it has a PDF output option and you can set it to combine all the sheets into one PDF file. Try it, much simpler to use a built-in tool.
Publish works pretty good, just tried it, never knew that option was there, I just have to separate few of my drawings, some of them I have multiple sheets in model space. Thanks for the suggestion Joe
Discussion_Admin
I am used to AutoCAD Architecture, but now have a new job that uses AutoCad LT 2013. How does one 'publish' more than one drawing tab to just one .pdf. HELP PLEASE!
Does ACADC LT 2013 have the PUBLISH command available on the command line? Just curious...
Thank you for responding to my dilemma of publishing more than one tab a once. The program I am using now is woodCADCAM OEM 2013 and runs with AutoCAD LT 2013. Unfortunately, PUBLISH, -PUBLISH, PLOT, blah, blah, blah does not work for this program. I am used to the full-blown program, AutoCAD Architecture 2019, so this is a bit of a downgrade for me command-wise.
I was looking for a command that will allow me to (publish, print, plot) all tabs in a drawing at once, just as the publish command works, but a command that will work in woodCADCAM OEM 2013. The response you gave me will work in every other world but doesn't work in mine, sadly.
Thank you for your time. That is truly appreciated. Have a super day!
