We are experiencing a strange error here. If a DWG file is opened via Windows Explorer instead of directly opening it in AutoCAD, sometimes saving is impossible. You simply can not see the directory tree, it makes no difference if the file is saved locally or on a network drive.
Has anyone had similar issues?
Best regards, C. Mayer
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
So if you open the DWG from ACAD LT : no problem !
If you open from Explorer, sometimes you can't rewrite it : File is Read-Only !!
OK what is your Launcher for the .DWG file type ??
Bye, Pat
Patrice BRAUD
