AutoCAD LT General
New Member
Message 1 of 11 (3,263 Views)
AutoCAD LT 2013 Fatal Error
3263 Views, 10 Replies
04-30-2012 03:57 PM
While inserting blocks into my dwgs I get this Auto CAD LT Error Aborting Message
FATAL ERROR: Unhandled Access Violation Reading 0x0040 Exception at d971cabbh
Ihave tried restarting the machine and repairing the program. My next step is a compltete reinstall.
Any answers to this problem?
*Expert Elite*
pendean
Message 2 of 11 (3,260 Views)
Re: AutoCAD LT 2013 Fatal Error
04-30-2012 04:00 PM in reply to: Barndog80
Where are the blocks from?
method of insertion?
If you tried to insert blocks from another source does it do the same?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
Message 3 of 11 (3,256 Views)
04-30-2012 07:27 PM in reply to: pendean
the blocks are from different dwgs located in a common folder on a remote server in the office
all methods of insertion were tried
the blocks had been inserting fine from the start of last month until yesterday afternoon.
*Expert Elite*
pendean
Message 4 of 11 (3,246 Views)
05-01-2012 04:42 AM in reply to: Barndog80
What changed yesterday afternoon? Did you change PCs? did the remote server reset? Where the files moved? Do you just need to restart your PC? Add hardware? Software?
Does this happen with all files, even if you start a new one? Grab blocks from files on your PC?
Message 5 of 11 (3,238 Views)
05-01-2012 09:19 AM in reply to: Barndog80
At the outset: My system is a brand new Alienware m17x r3 laptop with a quad-core intel i7, 16 GB of ram and well over 400 GB of empty hard disk space.
Even though no solution has been found yet for this, it is a breath of fresh air to see that someone else is airing the same frustraton. I'm not on LT, but the standard Autocad 2013 client (student version), and from what it looks like my problem is identical to yours. I had been inserting blocks into my drawings for at least 2 weeks without a hitch, then suddenly when I tried dragging one of them into the model space, I get the unhandled access violation error message. I used Autocad 2012 student from day one up until 2013 was placed up on the Autodesk student site for download, and not once did it ever give me this problem.
What is especially frustrating is that it seems to be hit and miss as far as when the program crashes. Sometimes I can work around it by right clicking the block thumbnail and hitting insert and it will let me place it in the drawing smoothly. Other times (most often, mind you) even that alternative will fail, and the same old maddening error message appears. I am at at a loss where to turn, because the bulk of my work as a student drafter is done in 2D, and I rely heavily on the sample blocks provided with the program. The student site's complaints forum seems to never be used by anyone actually working for Autodesk who might be able to forward the problem to the coders and engineers. My questions there relating to this topic go unanswered.
What I am hoping beyond hope for is a patch that could address this. I've done about a dozen clean uninstalls and reinstalls to no avail. I hope enough people have this issue that it becomes something that the coders deem worth issuing a patch for. Help please, Autodesk Gods!
*Expert Elite*
pendean
Message 6 of 11 (3,236 Views)
05-01-2012 09:21 AM in reply to: Matt_Wisehant
At least now we are establishing a pattern: did yours also stop working yesterday afternoon (or was that the day before)?
Have either of you tried Windows Restore feature to go back a week or two to when it all worked to see if something got installed that messed things up?
Message 7 of 11 (3,231 Views)
05-01-2012 09:43 AM in reply to: pendean
Yes, I tried system restore, and also repairing the program multiple times, in addition to doing clean uninstalls of the program, none of which fixed the issue. This occurs randomly no matter how I try to place the block into the program (i.e. click and hit insert or drag the thumbnail into model space to place the block).
This appears to be a problem that is in dire need of patching. I've done everything else I can possibly do. This never happened with 2012 at all, and as I said before I used it from day 1 until 2013 was posted.
BTW, thank you for your timely feedback. Getting responses is much appreciated.
Message 8 of 11 (3,230 Views)
05-01-2012 09:48 AM in reply to: pendean
To your initial question: The crashing and error message problem started happening about a week ago, and I had been using the program since it was posted in late March.
*Expert Elite*
pendean
Message 9 of 11 (3,200 Views)
05-01-2012 04:01 PM in reply to: Matt_Wisehant
Not sure a ramdon occurance will be patched unless it becomes a repeated problem everyone has: I've not seen it but I don't have 2013 in production work yet as I have not ported all of my customizations over from LT2012.
Message 10 of 11 (3,179 Views)
05-02-2012 06:44 AM in reply to: pendean
Thats what I was afraid of....it is hard to ascertain why such a thing would happen under otherwise completely normal circumstances. I was using the program strictly for 2D drafting, and had loaded no special scripts or anything else into it. It is a problem that I as a layman have zero possibility of finding a solution for, which is why I was beckoning someone like you who might have sway with Autodesk to at least make the suggestion that it needs to be checked out.
But that being said, your point is well taken. It is a question of priorities.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
