AutoCAD LT General
New Member
Message 1 of 4 (2,627 Views)
AutoCAD LT 2013 - Crashes at startup
2627 Views, 3 Replies
10-15-2012 02:53 PM
AutoCAD LT 2013 - Crashes at startup and haven't been able to use at all!
Autocad opens and them it closes itself very quick. It doesn´t give me any error. The program was running ok, until last week. Haven´t make any system changes
I´ve tried to uninstall and them install de program, reinstall :NET framework and still nothing
Please help
*Expert Elite*
Charles_Shade
Message 2 of 4 (2,604 Views)
Re: AutoCAD LT 2013 - Crashes at startup
10-16-2012 05:01 AM in reply to: cemexni
Since you have already tried a reinstall this may not work but s System Restore to a week or more ago may correct the error.
Do you allow Windows to automatically update your system?
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
More complete .NET fix if you did not go through this procedure:
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
New Member
Message 3 of 4 (2,588 Views)
10-16-2012 07:57 AM in reply to: Charles_Shade
Hi Charles, thanks for the reply
I removed all the autocad using the procedure you mention and using the cleanup utility for remove the .NET Framework, and still nothing.
I´m afraid the system restore is not an option for me, because is turned off in the pc.
Do you have any other ideas??
*Expert Elite*
Charles_Shade
Message 4 of 4 (2,583 Views)
10-16-2012 09:05 AM in reply to: cemexni
Another place to post for Installation Errors:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
If you are not receiving any warnings make sure you re-post that as well.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
