Installation & Licensing
AutoCAD LT 2013 64 bit download
17 REPLIES 17
Message 1 of 18
alifarhan123
21647 Views, 17 Replies
I am trying to download the AutoCAD LT 2013 64bit version. The first time i clicked download it had me install Akmai. After that I see the page where the download bar doesnt show any progress and below the download bar I see this message 'calculating time remaining'.
Your help is appreciated.
Thanks!
Farhan
17 REPLIES 17
Message 2 of 18
philip.s
in reply to: alifarhan123
Hello Farhan and welcome to the community.
The  'calculating time remaining' error is typically resolved by using a different internet browser. With that being said and as I'm already here, I've provided you with the following 24hr timed direct download link as a temporary workaround.
AutoCAD LT 2013 64BIT
Message 3 of 18
alifarhan123
Thanks, it worked.
Edited by
Discussion_Admin
Message 4 of 18
AngeloSW
in reply to: philip.s
Hi Philip. I had Autocad 2013 32 bit installed and now moved to a 64 bit OS. The download link supplied initially does not work anymore and I struggle to complete registration/activation process. Please assist?
Message 5 of 18
camilo.lemos
in reply to: AngeloSW
Hi @AngeloSW and welcome to the Autodesk Community!
You can download AutoCAD LT 2013 from our Virtual Agent linked here (click on Download Links, choose product and version).
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Camilo Lemos
Message 6 of 18
AngeloSW
in reply to: camilo.lemos
Works perfectly - Thanks very much.
Message 7 of 18
jeanPC7NP
Dear Phillip,
Could you perhaps provide the AutoCad LT 2013 Download Link.
I need to install a copy as I have changed machines . New unit does not have CD Drive.
Message 8 of 18
muriel.a
in reply to: jeanPC7NP
Hi @jeanPC7NP,
You can download AutoCAD LT 2013 from our Virtual Agent. Choose Download Links, click on products and version.
Muriel Assuncao
Message 9 of 18
oviljoen
in reply to: muriel.a
Hi Muriel.a
Our architect recently upgraded to a new laptop with 64bit operating system and no CD rom. I need to download the 2013 AutoCad LT 64bit in order to install.
Will you please assist with a link, the path (Virtual Agent) you had previously advised only goes back to 2015.
Thank you
Message 10 of 18
lynn_zhang
in reply to: oviljoen
Hi @oviljoen Welcome to Autodesk Community!
Autodesk supports products up to three versions past the current release. If the download you need is not located within the Virtual Agent, please contact Customer Care to see if your product is still available. Please note that any unsupported versions can become unavailable at any time.
Lynn Zhang
Message 11 of 18
Emmsleys
Hi @oviljoen
Were you able to locate a download file? Post back if you still need some help or direction on getting what you need for AutoCAD LT 2013.
Thanks.
Smiley Happy
Sarah Emmsley
Technical Support Specialist
Message 12 of 18
oviljoen
in reply to: Emmsleys
Hi Sarah
I have managed to install remotely with the disk.
Thank you
Message 13 of 18
klin506
Hi @Emmsleys
I'm in the same position as @oviljoen and am in need of the download link for AutoCAD LT 2013. Thanks for your time.
Message 14 of 18
mdavis22569
in reply to: klin506
@klin506
go to AVA.autodesk.com
do a chat with agent, if you have a valid license they will give you a download link for it
Mike Davis
Message 15 of 18
Emmsleys
HI @klin506
Were you able to get your download link via AVA?
Post back in the thread if you need continued support with AutoCAD LT, I'd be happy to help to the best of my ability.
Smiley Happy
Sarah Emmsley
Message 16 of 18
Even i am looking for AutoCad LT 2013 64-bit setup.
Message 17 of 18
bklearn
I have read about the Autodesk Virtual Agent and the download of AutoCAD_2015_English_Win_64bit_R1_dlm.sfx.  I downloaded it and have a few questions.
FYI;
I am an Expect with AutoCAD through 2005 and a Retired Designer.  I am looking to get AutoCAD for a few projects.
Questions;
What is the deal with the AutoCAD_2015_English_Win_64bit_R1_dlm.sfx.exe file?  Will it install CAD?  Will this come with the License etc.?
Message 18 of 18
The file you downloaded from the virtual agent is in a compressed state. You double click on that file and it extract the entire software media. Once the extraction is completed the installation will start. But my question to you. Have you gone to an authorize reseller or the Autodesk e store and subscribe to an autocad 2018 which will give you the entitlement to the 2015 version? Meaning you need to obtain a license to authorize your installation.
Mark Lancaster
Administrator Productivity
