I am trying to download the AutoCAD LT 2013 64bit version. The first time i clicked download it had me install Akmai. After that I see the page where the download bar doesnt show any progress and below the download bar I see this message 'calculating time remaining'.
Your help is appreciated.
Thanks!
Farhan
Solved by mdavis22569. Go to Solution.
Solved by oviljoen. Go to Solution.
Hello Farhan and welcome to the community.
The 'calculating time remaining' error is typically resolved by using a different internet browser. With that being said and as I'm already here, I've provided you with the following 24hr timed direct download link as a temporary workaround.
Hi Philip. I had Autocad 2013 32 bit installed and now moved to a 64 bit OS. The download link supplied initially does not work anymore and I struggle to complete registration/activation process. Please assist?
Hi @AngeloSW and welcome to the Autodesk Community!
You can download AutoCAD LT 2013 from our Virtual Agent linked here (click on Download Links, choose product and version).
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Dear Phillip,
Could you perhaps provide the AutoCad LT 2013 Download Link.
I need to install a copy as I have changed machines . New unit does not have CD Drive.
Hi @jeanPC7NP,
You can download AutoCAD LT 2013 from our Virtual Agent. Choose Download Links, click on products and version.
Hi Muriel.a
Our architect recently upgraded to a new laptop with 64bit operating system and no CD rom. I need to download the 2013 AutoCad LT 64bit in order to install.
Will you please assist with a link, the path (Virtual Agent) you had previously advised only goes back to 2015.
Thank you
Hi @oviljoen Welcome to Autodesk Community!
Autodesk supports products up to three versions past the current release. If the download you need is not located within the Virtual Agent, please contact Customer Care to see if your product is still available. Please note that any unsupported versions can become unavailable at any time.
I have read about the Autodesk Virtual Agent and the download of AutoCAD_2015_English_Win_64bit_R1_dlm.sfx. I downloaded it and have a few questions.
FYI;
I am an Expect with AutoCAD through 2005 and a Retired Designer. I am looking to get AutoCAD for a few projects.
Questions;
What is the deal with the AutoCAD_2015_English_Win_64bit_R1_dlm.sfx.exe file? Will it install CAD? Will this come with the License etc.?
Mark Lancaster
& Autodesk Services MarketPlace Provider
