I am having trouble getting AutoCAD LT 2012 to run on a Windows 7 64 bit machine (it's an HP Compaq 6000 Pro). This is a new installation. It will open up correctly under my user profile, which is an admin, however, it will not open up correctly under the user's profile. Everytime I try to open it under the user's profile, the error message "Customization file load failed: File not found: acadlt".
Here is what I have tried after searching the web:
I have made the user a local admin and then a domain admin (separately and with a reboot after each change) - this did not change the problem.
I have deleted the profile created in the registry - this did not change the problem
I have already done a reload of AutoCAD 2012, but not a full uninstall of all the parts and then reinstall like that, but that is my next step.
Any and all help would be greatly appreciated!
Thank you,
Stephanie Gugle
HelpDesk Support
