Show only
Search instead for
{color:#000000}Last week while I was working, I noticed my copy command no longer would allow me to pick more than one object unless I used a crossing window. Later I realized that I could no longer pick more than one object regardless of the command. I tried move but could only pick one object unless using a crossing window. This is very frustrating as I sometimes need to pick several different objects in various areas of the drawing to move or copy to another location. Any suggestions or ideas as to what happened?
{color}
Pickfirst variable? Look at Options - Selection as well
George Drayton CD-CAD Ltd Christchurch New Zealand.
it does this in any drawing that i open. i have not changed any settings. it just started "out of the blue" and it is driving me crazy. i will try the suggestions listed and see if any of them help. will let you know shortly. thanks
I tried the PICKFIRST command. The value was set to <1>. I left it as is and tried the PICKADD command. The value was set to <0>. I changed the value to <1>. I can now pick all the objects I want to copy or move! I have no idea how this value was changed from a <1> to a <0>. I am the only person in the office that will even attempt to make such a change. Has there been a recent update for 2009 LT that may have changed the value? I have it set up to automatically update.
Regardless, the problem has been solved. Thanks for the help!
