Some background - I have been running AutoCAD since version 10. Currently my machine (a dell lattitude E6400) is running AutoCAD 2012 just fine. No problems with memory or CPU usage
We recieved the next version of AutoCAD 2014, which I installed. I also took the same disk home and installed it on my home computer. It is legal to do this and the software runs fine on that machine. I had a problem, where it crashed out my system when I first tried to use it. I only had two drawings open. I asked my IS support about it....but there was no error log to check on my computer. So thinking it was the software, I removed it and re-installed it. No difference in the results.
The problem is that when I run the software, the CPU usage will hit between 95-100% utilization and the physical memory used keeps climbing from 2Gb (before startup) until it uses over 3.2Gb (haven't let it run longer than this). Other information for you to consider....I have had the software running "by itself" without any other stuff running. The cursor continually keeps spinning, while allowing you to operate inside AutoCAD, don't understand this. Also....if I "quit" AutoCAD, the actual executable is still registering on the "processes" tab and holding the usage up until I "force" it to close.
The reason I am asking for help is basically that the actual CPU usage of the exectuable is no different from one version of AutoCAD to the other....but the overall CPU usage hits so hard, it will eventually crash the system. I can see no difference in the two pieces of software running, but I have this problem.
Anyone have any ideas?
Not precisely. Its more a matter of stopping the process from running automatically. Do some searching here and in the AutoCAD forum, there's some excellent threads on how to manage installation so that features are disabled without leaving programmatic potholes.
Hello from France
You can disable some Autodesk Services (or some others) ... If you are a Local Admin !?
Configuration / Admin Tools / Services / etc ... PLEASE be careful !
Click on a Autodesk Service (Autodesk Content Service for example) then Right Button then Properties
then "MANUAL Startup" instead of "Automatic Startup" !
Bye, Pat
Patrice BRAUD
There are some updates/hotfixes for AutoCAD 2014:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240618
It possibly could be the extra features that come with AutoCAD 2014, but those should be running under their own EXE files, so you would see the CPU usage on something other than acad.exe in the Task Manager.
What version of Windows are you using? It may be that you are experiencing a driver conflict. Does you video driver need to be updated? Here are some links to get an update:
http://www.nvidia.com/Download/index.aspx
http://support.amd.com/us/Pages/AMDSupportHub.aspx
http://www.intel.com/p/en_US/support/detect
