AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD 2013 & Geotiffs
8 REPLIES 8
Message 1 of 9
3162 Views, 8 Replies
I design agricultural irrigation layouts using AutoCAD 2013, and have found a need to load Geotiffs into autocad to aide the designs.  is there a way to insert a Geotiff so that it sits in the right place "inworld" ?
thanks
8 REPLIES 8
Message 2 of 9
Charles_Shade
This is the LT Forum so you may be in the wrong place for your query but anyway:
Under the Tools Menu dropdown you can set the Geographic Location VIA Coords, or Google Earth.
May be worth trying there.
Message 3 of 9
in reply to: Charles_Shade
Thanks for the help,  it tells me
                    Class not registered.
  I'm sure I'll suss it out
Thanks again Charles
Steve
Message 4 of 9
braudpat
Hello
I think that ONLY AutoCAD MAP ou AutoCAD CIVIL can insert automatically "at the right place" :
- GeoTiff files
- TIF+TFW or JPG+JGW files
- ECW / SID files
- etc
Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 5 of 9
Nik-D
There is a workaround but it is clunky and painfull. The link below give guidance on how Geo referenced files are attached. I've done it a couple of times but its labourious. It could be automated with LISP but i dont know how.
http://www.centremapslive.co.uk/files/autocad_images.pdf
You will need the XML file that should be with the TIFF file. From that ou can open the file and get the co-ords directly.
HTH
Message 6 of 9
pendean
in reply to: Nik-D
Thanks for sharing.
Message 7 of 9
in reply to: Nik-D
Thanks very much thats about the best one I can match up to
cheers
Message 8 of 9
vladimir_michl
You can use the GeoRefImg utility (free) to reposition GeoTiff files but not in LT - GeoRefImg is a LISP tool.
See: http://www.cadforum.cz/cadforum_en/how-to-place-geotiff-images-automatically-to-right-positions-tip9...
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Message 9 of 9
Lisp is not available in OOTB AutoCAD LT.
It is a violation of the EULA to make LT LISP capable (at least here in the States.)
”Boost
