I design agricultural irrigation layouts using AutoCAD 2013, and have found a need to load Geotiffs into autocad to aide the designs. is there a way to insert a Geotiff so that it sits in the right place "inworld" ?
thanks
Solved by Nik-D. Go to Solution.
This is the LT Forum so you may be in the wrong place for your query but anyway:
Under the Tools Menu dropdown you can set the Geographic Location VIA Coords, or Google Earth.
May be worth trying there.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thanks for the help, it tells me
Class not registered.
I'm sure I'll suss it out
Thanks again Charles
Steve
Hello
I think that ONLY AutoCAD MAP ou AutoCAD CIVIL can insert automatically "at the right place" :
- GeoTiff files
- TIF+TFW or JPG+JGW files
- ECW / SID files
- etc
Bye, Patrice
Patrice BRAUD
There is a workaround but it is clunky and painfull. The link below give guidance on how Geo referenced files are attached. I've done it a couple of times but its labourious. It could be automated with LISP but i dont know how.
http://www.centremapslive.co.uk/files/autocad_images.pdf
You will need the XML file that should be with the TIFF file. From that ou can open the file and get the co-ords directly.
HTH
You can use the GeoRefImg utility (free) to reposition GeoTiff files but not in LT - GeoRefImg is a LISP tool.
Vladimir Michl, www.cadstudio.cz www.cadforum.cz
Lisp is not available in OOTB AutoCAD LT.
It is a violation of the EULA to make LT LISP capable (at least here in the States.)
