2012 LT about a year old, just recently started shutting off/closing unexpectedly during a drawing command (pline, copy, offset etc...) or when using numeric keys on keyboard. seems like everything else works ok. no error messages. nothing. just dissapears. gone.
any ideas?
nothing changed on PC recently. PC itself is just a year old (same as 2012 LT) its not a heavily used machine or software
havent tried a windows system restore, have however kept up with all windows updates
very very frustrating, have clients waiting for work to be done and cant get it done
The Windows updates could be the culprit.
.NET updates, at least for me, wreak havoc from time to time. You may be seeing the results of one after coming back to the machine from some time a while ago.
The Restore may work but you would need to go back to prior to the last time your CAD worked properly.
If not a Repair Install may fix you up.
The next fixes are more drastic.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
