I have a single user with this problem. We use a batch printing program to print drawings and it works for everyone but him. Each time the batch ulility goes to access AutoCAD, it will say:
This version of AutoCAD was not installed properly and some features may not run correctly. You should reinstall AutoCAD immediately to make sure all features are working properly. Do you wish to continue anyway?
I've gone through a few technical documents where I check the registry settings at HKEY_CLASSES_ROOT\.png key and I've also removed all instances of .NET and reinstalled them to no avail.
Any suggestions on how to fix this?
He is on XP SP3.
