AutoCAD LT Forum
Adjustiing what I would call the zoom ratio in Layout space.
2 REPLIES 2
380 Views, 2 Replies
I have recently updated to the 2013 software, and have been trying to get it set back up to my normal settings.  One of the settings I vaguely remember editing was when you are in a layout view looking through a view port and you zoom in to get a part to fit in the viewport;  you zoom in and back out and the model space gradually shrinks with each time.  The problem I am having with it is that in my new 2013 software the "shrinkage is so small that it takes forever to get something to fit into the view port.  As a result, rather than zooming with the wheel once or twice untill the part and diminsions fit within an area that looks nice, you have to zoom in and out with the wheel say 20/30 times and that still only gets it to look legable (not touching any borders).  I canot remember the command i need to envoke to adjust this property.  Does anyone know how to adjust this setting?
Thank you,
Boston
2 REPLIES 2
sthompson1021
Hi, at the comand line type zoom and then it will prompt you to window the area you want.
drjohn
If you want to adjust the zoom of the scroll wheel the command is ZOOMFACTOR
HTH
DJ
”Boost
