AutoCAD LT Forum
Add menu in the Quick access Toolbar
3 REPLIES 3
c.dufrene
1890 Views, 3 Replies
Hi guys,
I already add in the Quick Access Toolbar the "Layer Combo Control" and the "Ribbon Combo Box - Linetypes"
I would like to add also "Ribbon Combo Box - Object Color" BUT it seems impossible...
I copy it from Panels - Home - Properties and put it into Quick access Toolbar, but it never shows up and worse when I go back to CUI it has dissappeared... Smiley Frustrated
The only things that works is the "color" function.
Any ideas ? Thanks.
3 REPLIES 3
pendean
in reply to: c.dufrene
Right-click on any element in any panel: if it gives you the option to place it on the QAT you can do so, if not then it will not work.
Another method: click on the down arrow for the QAT (next to the linetype pulldown in your screenshot, choose MORE COMMANDS and try it that way too.
In your case, with your specific desired element, that's not an option from what I can tell.
c.dufrene
in reply to: pendean
Unfortunately you are right Dean, neither solution works Smiley Sad
Thanks anyway.
pendean
FYI, whenever you make a change to the screen menus always manually save your active workspace. use WSSAVE command.
”Boost
