AutoCAD LT Forum
AUTODESK LICENSE TRANSFER PROBLEM
11 REPLIES 11
Message 1 of 12
725 Views, 11 Replies
I have transferred my license from my machine to another machine in my office. while transferring again getting some error message. I have attached the error messgae along with this. Please help me to transfer my license back. Also please clarify why this error coming....
Edited by
Discussion_Admin
11 REPLIES 11
Message 2 of 12
pendean
Looks like you've done this more than once before and never returned it: and you reached a limit for doing so now.
Why are you "doing it again"? There is no workaround, you need to put the first transfer back.
Message 3 of 12
We having two systems, both having inventor software but one license. we will transfer the license between those systems while required. now presently the license is active in one system. I couldnt able to transfer the license from the system. Is there any count for transferring license between systems?
Message 4 of 12
pendean
Yes, you can only do the transfer once. Sounds like you need to purchase another license, or contact a reseller about acquiring a server-based license for Inventor if one is offered.
INVENTOR forum is here, you are posting in an AutoCAD forum:
http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
Licensing and license tranfer tips and help are at:
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=18269590
Installation Help from Autodesk forum is at:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Autodesk support is now on Twitter 24/5 (@autodeskcare): http://autode.sk/sbGrpx
If you are on subscription, visit your Autodesk
Subscription Page for direct Autodesk Help:
http://www.autodesk.com/subscriptionlogin
Contact a Reseller for support (not free):
http://www.autodesk.com/reseller
Message 5 of 12
in reply to: pendean
In stand alone license it is mentioned as we can do the license transfer through LTU as many times we want. Then why this error message coming.
Message 6 of 12
pendean
You have to put the first one back before you can transfer again: you have one ball (license), you can transfer it to Bob whenever you want, but if Steve needs it then Bob has to bring it back first. Simple concept.
No one here is going to tell you much else, we are all end users: use the links I posted to ask Autodesk direct, unless you fear the real answer might hurt more 🙂
Message 7 of 12
This where USB hardware dongles are a perfect soltion
Message 8 of 12
Is there a limit to how many times we can transfer a standalone license of ACADLT?
I tried to transfer ACADLT2011 but autodesk website refused to cooperate. And I'm deeply puzzled as to why my previous registrations with autodesk did not show up anywhere. I really wonder how does autodesk record keeping of ACADLT of standalone licenses work?
I have other software products with Adobe and it keeps my records perfectly clear on a list.
Message 9 of 12
Charles_Shade
You can tranfer the license using the LTU to one additional seat of LT thus rendering the tranferee unlicensed.
You then would need to transfer the license from the second install to a third or back to the first.
Then if you wished you could move it from the first or third back to the second or the fourth.
And so on.
The LTU is also a bit touchy and does not always play well.
In all cases there is only one license and one valid activated copy of LT at any given time.
Message 10 of 12
in reply to: Charles_Shade
The scenerio is such that new PCs are being purchased and the ACADLT licenses move to newer PCs. Any suggestion for a better solution and a more economical way of doing it? Thanks.
Message 11 of 12
pendean
Leave LT on original PC
Install and authorize LT on the new PC
Ensure all works and nothing is missing on the new PC
Uninstall LT from the old PC
A simple not complicated one-for-one swap with no downtime should anything go wrong anywhere. Any other method, from any vendor, leaves you open to unrecoverable errors IMHO.
Message 12 of 12
yep, seems like this is the best route. So much for LTU (license transfer utility) thing.
”Boost
