AutoCAD LT General
Member
Message 1 of 11 (2,674 Views)
APPCRASH , AutoCAD LT has stopped working
2674 Views, 10 Replies
09-22-2009 06:44 AM
HELP!
-Get the following error when plotting or previewing in AutoCAD LT 2010, using Vista Ultimate, plotting to system printer HP 5100
-Only faults when selecting 11x17 paper sze, letter size plots normal
-Printer works fine with other apps
Problem Event Name: APPCRASH
Application Name: acadlt.exe
Application Version: 24.0.55.0
Application Timestamp: 499008e6
Fault Module Name: StackHash_90cf
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791adec
Exception Code: c0000374
Exception Offset: 00000000000a6e97
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 90cf
Additional Information 2: e9e40b45b3fa420ce97bf78fe7137a7f
Additional Information 3: c0fc
Additional Information 4: 13a1d1c64633765bd17ddf062cf01078
*Dean Saadallah
Message 2 of 11 (2,675 Views)
Re: APPCRASH , AutoCAD LT has stopped working
09-22-2009 06:47 AM in reply to: dispensetech
Did this problem just start?
using a system printer driver, or PC3 file?
Dean Saadallah
http://LTisACAD.blogspot.com
Member
Message 3 of 11 (2,675 Views)
09-22-2009 06:49 AM in reply to: dispensetech
Yes, just started today. Started using AutoCAD LT 2010 on new computer about 1 week ago.
Same fault using system driver or .PC3 file
*Dean Saadallah
Message 4 of 11 (2,675 Views)
09-22-2009 06:57 AM in reply to: dispensetech
Windows Restore, see what got installed overnight, go back to yesterday's
settings if needed.
Dean Saadallah
Member
Message 5 of 11 (2,675 Views)
09-22-2009 08:28 AM in reply to: dispensetech
No luck. Restored to yesterday's settings, also removed and re-installed AutoCAD.
I realized that this only happens when plotting to 11x17 paper, other programs print to 11x17 without any problem.
Member
Message 6 of 11 (2,675 Views)
09-22-2009 11:32 AM in reply to: dispensetech
FYI
Contacted AutoCAD tech support. Was told that this is a known problem with AutoCAD 2010, 64-bit Vista and HP 5100 series printers.
Printer works fine for every other application EXCEPT AutoCAD 2010. Does not work with AutoCAD TrueView either, same issue.
Was told to try and roll back my printer driver, did not help.
Was told that the only other work around was to print to PDF and then print 11x17 through Adobe. This works, but very time consuming.
Any other suggestions are MUCH appreciated.... Thanks...
*Dean Saadallah
Message 7 of 11 (2,675 Views)
09-22-2009 01:00 PM in reply to: dispensetech
HP5100 is an old and great workhorse, I still have one and use it daily: but
I'm running 32bit OS here. Now I know what will happen if I go 64bit: thanks
for the heads up.
But why would it just stop working one day out of the blue: that makes no
sense.
Dean Saadallah
New Member
Message 8 of 11 (1,875 Views)
10-14-2011 08:01 AM in reply to: dispensetech
My crash is with Revit 2011
Any Ideas why, this has been an on going problem when I try to modify any materials.
Problem signature:
Application Name: Revit.exe
Application Version: 2012.0.2011.309
Application Timestamp: 4d785e92
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.17514
Fault Module Timestamp: 4ce7c8f9
Exception Code: c0000005
Exception Offset: 0000000000028c28
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 8d2a
Additional Information 2: 8d2ac9ded0a2126640615ccbe07f9afb
Additional Information 3: cd21
Additional Information 4: cd21f83e2aa85fab0568643ae4a8f566
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
*Expert Elite*
Charles_Shade
Message 9 of 11 (1,872 Views)
10-14-2011 08:40 AM in reply to: slocum
Revit Forum
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
New Member
mtjeley
Message 10 of 11 (1,692 Views)
01-30-2012 08:14 PM in reply to: dispensetech
I have just installed my new 2012 autocad lt but it will not open
with the message a problem has caused autocad to stop working.
I have upgraded my graphic card Driver and I do not have a hp printer.
Locale ID: 1033
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
